clutch basket play
Old Jun 28, 2013 | 09:53 AM
blackbear's Avatar
blackbear
Default clutch basket play
I'm working on getting my '93 fxdwg back to together and I was going to check the compensator sprocket to the clutch basket alignment and I noticed that the clutch basket is moving in and out about 1/16 but it has no side to side play just in and out.The hub nut is tight.I pulled the clutch plates out and spun the hub bearing and it sounds ok and spins free.also the main shaft isn't moving in and out like its supposed to.Is the basket supposed to be able to move like that or is my hub bearing bad ?
Old Jun 28, 2013 | 09:58 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I don't know what it is but your clutch basket shouldn't move at all let alone 1/16th of an inch.
Old Jun 28, 2013 | 01:08 PM
Schex's Avatar
Schex
I 'd say it's ok,
your just grabbing the ring gear in one spot and pushing in and out correct?
Old Jun 28, 2013 | 11:07 PM
blackbear's Avatar
blackbear
I pulled the clutch off and put it on the bench to get a better look at what was moving and it was the bearing floating in the clutch basket.I punched out the hub from the bearing and I took out the snap ring holding the bearing in and the bearing came out with little to no resistance.I think that bearing was supposed to be a press fit in the basket.I guess I need a new basket and a new hub because the snap ring groove on the hub has a 1/2 inch crack in it from either me punching it out or something else.
daven9113
EVO
15
Jul 7, 2021 10:50 AM
blair
Jun 25, 2012 05:24 PM
1sttinker
Jan 20, 2012 08:21 PM
DJ Baar
Oct 5, 2011 10:49 AM
JustDave71
Aug 20, 2010 08:17 PM
