minor oil leak from this plug
Old Jun 27, 2013 | 02:45 PM
junglejoe's Avatar
junglejoe
Default minor oil leak from this plug
Got a minor oil leak from this plug,I guess you have to take the primary cover off to fix it?
Old Jun 27, 2013 | 02:50 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
This was posted in another thread
Last
fall, while doing some waterproofing on something else, I bought some "flowable"
silicone windshield and glass sealer (Permatex) at the auto parts store. I had
some left in a syringe, so I figured it couldn't hurt. I cleaned the area around
the stator plug, soaked it with electrical contact cleaner to degrease the plug
and case as well as I could, dried it, then laid a small bead of the flowable
sealer around the junction of the plug and case. In a minute or so, capillary
action drew the sealer into the joint and it disappeared. I let it cure
overnight, then put the bike back into service. I really didn't expect it to
work since nothing else had, but it's been dry for almost 9 months now.
Old Jun 27, 2013 | 02:58 PM
junglejoe's Avatar
junglejoe
Thanks, might have to give it a try, so I assume its sealed by an O-ring or something?
Old Jun 27, 2013 | 03:10 PM
Dr.Hess's Avatar
Dr.Hess
No it is just sealed by the rubber plug on the end of the stator wires. I put some Ultra Black silicone on the outer plug and pushed it in a couple years ago. Hasn't leaked since. That flowable stuff sounds interesting.
Old Jun 27, 2013 | 08:29 PM
Uncle G.'s Avatar
Uncle G.
That was my post. I've tried injecting regular silicone RTV into the joint, but after about two weeks it leaked again. As I said, I didn't expect the flowable sealer to work, but it's still holding out.
Old Jun 28, 2013 | 06:46 AM
ironoxide's Avatar
ironoxide
Default agree
As Uncle G recommends, the Permetex flowable silicone works great. It's maximum service temperature is 400 degrees F, which is more than enough for this application. I tried it two weeks ago...so far so good.
Old Jun 29, 2013 | 06:40 AM
junglejoe's Avatar
junglejoe
Got some out in the garage...
lmz5150
EVO
May 24, 2018 12:25 AM
Budsdeuce
Jan 21, 2014 05:16 PM
PPBART
Jun 8, 2013 10:01 AM
HDPHILS
Apr 26, 2010 10:03 PM
Viejo
Apr 17, 2008 03:12 PM
