Occassional problem
Old Sep 8, 2023 | 10:06 AM
de ed's Avatar
de ed
Default Occassional problem
2005 Dyna with fuel inj and 11,000 Mies. Starts, runs, travels and then whenever shuts down. Wait 20 or 30 minutes and starts up again. Put in new plugs, no better. Fuels ok and no codes.Thinking maybe fuel filter, already ordered. Any other ideas.
Old Sep 8, 2023 | 10:19 AM
Rounders's Avatar
Rounders
Electric stays on, bike just dies? Does it turn over in those 30 minutes? I'd check spark. In autos I have fuel pressure regulators do that.
Regardless based on age, at some point replacing fuel pump isn't worse idea. I understand it is your money that you would have to spend, not mine.
Old Sep 8, 2023 | 11:22 AM
KK0G's Avatar
KK0G
You didn't specify but I'm assuming it cranks but doesn't start? If that's the case then it's missing either spark, fuel, or compression. You can pretty much rule out compression because compression isn't something you generally lose and then it returns so that leaves spark or fuel. Pull a plug wire and see if it has spark while cranking and/or shoot a bit of fuel into the intake. Until we have that info it's just an expensive guessing game.
Old Sep 8, 2023 | 11:40 AM
nevil's Avatar
nevil
You might need more than just the fuel filter. Check the lines in the tank and the regulator by priming the fuel pump. It's a good chance you'll need to replace that setup.
Old Sep 8, 2023 | 11:45 AM
WONKEY's Avatar
WONKEY
I would check for spark first, I have seen coils break down when they get hot, once they cool down they work fine for awhile, make sure you are getting a strong spark, a weak spark will prevent the bike from starting as well. Then I would look at fuel.
Old Sep 8, 2023 | 11:58 AM
springers4ever's Avatar
springers4ever
Cool Over heating ...
How far are you "travels" ..before it shutdown...in traffic, rolling down hi way ...etc..???
could it be overheating ??? have any way of checking head/engine temp....???
Have an infrared temperature gun..by chance ???
Old Sep 11, 2023 | 09:18 AM
propflux01's Avatar
propflux01
Might want to put this in the dyna repair section, unless you’re selling the bike!
Old Sep 12, 2023 | 06:45 PM
Lonewolf176's Avatar
Lonewolf176
^^^^^^Yes. While your waiting replace the crank position sensor
sb2203
General Topics/Tech Tips
Sep 16, 2015 10:45 AM
cdavidj
Sep 1, 2015 11:06 AM
MundySue
Aug 30, 2012 01:33 PM
Scubba2
Jun 29, 2012 09:03 AM
Skulls
Oct 28, 2004 02:27 PM
