2016 Fat Boy S engine knocking suddenly
Old Oct 19, 2023 | 08:51 PM
CurtS's Avatar
CurtS
Stage I
Default 2016 Fat Boy S engine knocking suddenly
We out for a ride and heard this quiet knocking sound at first. It's gradually grew louder until it was much loader than the exhaust by the time i was able to make it back home. Sounds like it's coming from the front piston and it's pretty rhythmic with the engine.
I have a 2016 Fat boy S with about 38k miles on it and the sound just started. Any ideas?
Old Oct 19, 2023 | 09:07 PM
TwiZted Biker's Avatar
TwiZted Biker
Start by checking the pushrods, may have dropped a lifter.
Old Oct 20, 2023 | 08:34 AM
djl's Avatar
djl
After checking the pushrods, compression and leak down tests.
Old Oct 20, 2023 | 12:40 PM
ntraindavefl's Avatar
ntraindavefl
If it’s in time with the front piston then I’d pull the plug, put cylinder BDC and borescope the cylinder. If there’s an oiling problem for just a short time the heat and out of round damage can be irreversible and a top end rebuild needed
Old Oct 20, 2023 | 01:40 PM
Hilly13's Avatar
Hilly13
Pull your oil filter and cut it open, if it's got metal in it and it's knocking the big end has probably let go! i know a fellow that had a softail slim S, same engine as yours, HD replaced his engine twice under warranty before he made them take it back! I have a slim s as well, from new, no problem. I hope that's not it.
Old Oct 20, 2023 | 01:46 PM
2500hdon37s's Avatar
2500hdon37s
Start it up (with the bike in Neutral) and hold the throttle wide open. The knocking will either sort itself out or expose what the issue is rather quickly.
Old Oct 20, 2023 | 02:28 PM
Hilly13's Avatar
Hilly13
That'll do it haha
MNiceGuy
Milwaukee Eight (M8)
21
Sep 28, 2021 01:43 PM
FatBoylo13
May 14, 2021 10:17 PM
Chris Linssner
Jun 1, 2017 03:06 AM
monyman
Harley Davidson Videos
Jan 25, 2008 08:34 PM
