2012 flhx please help
Old Dec 3, 2023 | 11:46 AM
  #61
memphisharley's Avatar
memphisharley
got a engine from my bud 0.0003 runout. just about got everything cleaned up and flushed. do I need to remove oil pan.
thanks
Old Dec 3, 2023 | 12:05 PM
  #62
memphisharley
uploaded pics
Attached Thumbnails 2012 flhx please help-17016266275118630186281875799375.jpg   2012 flhx please help-17016266435105225763745054166358.jpg
Old Dec 3, 2023 | 02:55 PM
  #63
Harley_ish's Avatar
Harley_ish
thanks
How 'bout 0.003"
Old Dec 3, 2023 | 04:40 PM
  #64
Max Headflow's Avatar
Max Headflow
thanks
If the scavenge pump didn't have any crap in it, you are probably OK on the oil pan.. When I blew up my FXDX, broken rod, the pump was clear. I didn't bother with the pan.. I figure it probably made less than 10 revs before it locked up.. Oil pump and cam plate were still good. Flip side is that on a 2012 bagger, it's not too hard to remove the oil pan in the frame to have a look. If it does have crap, typically best to replace as the baffle is not removable..
Old Dec 3, 2023 | 05:06 PM
  #65
memphisharley
thanks max.
oil pump and cam plate looks good. no scoring or metal inside either. guess I gotta go ahead and pull the rear tire and drop the pan and have a look see. it was so much metal in the cam chest i don't feel comfortable not verifying after I've came this far.
Bakdrft
Exhaust System Topics
Apr 3, 2013 03:28 PM
1/2crazedbikr
EVO
Nov 13, 2012 11:20 AM
Bodean46
Oct 12, 2011 07:14 AM
05HARLEYMAN
Sep 27, 2007 07:39 PM
alvinlee
Mar 21, 2007 12:46 PM
