Cam chest tapping when warm
Old Jan 28, 2024 | 06:31 PM
911diver's Avatar
911diver
5th Gear
Default Cam chest tapping when warm
Finished a stage IV build on a 107. Had a delay in installing pushrods. Lifters were soaked but installed rods 2 days later.
initial start up valve train tapping heard. Rods backed off from 4 to 3-1/2 turns. Now Cold start no valve train tapping, once warms up, tapping heard.
did lifters drain and 4 turns was too much, once engine warms lifters fill and 3-1/2 turns is still too much? Back off another 1/2 turn? adj once engine warms/pressures up?
Old Jan 28, 2024 | 06:43 PM
Since 1968's Avatar
Since 1968
The number of turns recommended depends very much on which adjustable pushrods you're using. The threads per inch matter. Usually the manufacturer specifies the number of turns or sometimes flats to put the lifter in the middle of its range, i.e. .100" of the total .200" of travel. Some posters on this forum, including me, found that their lifters didn't get quiet until the pushrods were extended further than the recommendation. In my case I went to .125". Note, I am using the word 'quiet' to mean acceptably low. I've never managed to get my motor to be free of valve gear noise.
Old Jan 28, 2024 | 10:05 PM
Max Headflow's Avatar
Max Headflow
107 what? M8? TC? Evo SnS? Backing off typically won't cures the noise, going deeper will.
Old Jan 29, 2024 | 09:07 AM
911diver's Avatar
911diver
5th Gear
didn’t know HD made a 107 TC, Evo
Old Jan 29, 2024 | 09:15 AM
WONKEY's Avatar
WONKEY
He was asking what engine do you have and what lifters and push rods did you use.
Old Jan 29, 2024 | 10:47 AM
Max Headflow
They didn't but SnS did make an EVO. 4 x 4 1/4 bore/ stroke. Good motor.
Old Jan 29, 2024 | 06:49 PM
ntraindavefl's Avatar
ntraindavefl
Warm ticking can happen wout installation problems.
What cams? What AC? Was rocker shaft endplay checked? What brand lifters? There’s too much not mentioned for anyone to help. Adjusting pushrods probably not the answer
jake24lt
Milwaukee Eight (M8)
11
Apr 12, 2024 05:42 PM
briggs07
14
May 4, 2022 04:52 PM
Mac daddy 103
14
Apr 24, 2022 09:38 PM
cowentz
Mar 9, 2012 08:53 AM
jhr
Exhaust System Topics
Aug 20, 2009 11:57 AM
