First time lapping valves
Old Mar 25, 2024 | 06:45 AM
Notgrownup's Avatar
Notgrownup
New valves please.
Old Mar 25, 2024 | 06:57 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Why not have the valves reground and the seats recut?
The pitting on the valve shown looks to be pretty deep and if reground may be too much off the valve face.
Just my opinion, I would take it to someone that works on heads and get their expert analysis.
Hard to really know unless the valve(s) were in hand and not looking at an internet picture.
Old Mar 25, 2024 | 07:00 AM
stixvrad's Avatar
stixvrad
I agree with everything others have said. You need a valve job. If you want to prove it out further, test the valves ability to seal against the seat. Reassemble the heads and position each port one at at time so they're facing up.. Pour gasoline into each the port and watch for gas to run out of the valve/seat .
Old Mar 25, 2024 | 07:57 AM
PeterB's Avatar
PeterB
Cheapest way might be get those pitted valves refaced in a valve grinding machine at a machine shop. The seats look passable, although a little wide but still useable.
Take the heads and valves in and get the machine shop guys to look at it in the flesh and give you their opinion. Take them the factory manual about how deep you can cut those seats vs valve stem stick-out too. And see what they think about the valve to guide clearance/wear. They will need the factory manual specs for that too.
Old Mar 25, 2024 | 08:03 AM
Uncle Larry's Avatar
Uncle Larry
"Resurfacing" the valves ... Remember that the more grinding that is done on the valve the more material is being removed ... This leaves much less material at the outer edge of the valve ... Ever hear of a "burned valve" ... That is what can / will happen if you get too aggressive
Old Mar 25, 2024 | 08:34 AM
Max Headflow's Avatar
Max Headflow
Didn't know your micrometer eyeball was that good..
As stated previously, check the stems and guides for wear, the valve end for pitting. Grind the valve and check how much margin was left.. Not enough replace the valves. I used to own a Snap on valve and seat grinder. Did a lot of valve jobs with them mostly HD and Honda. Now, I'll simply replace the valves since I too lazy to send them out.. If replacing the valves, I'd recut the seats. If replacing the guides, seats will need recut..
Old Mar 25, 2024 | 08:41 AM
Uncle Larry
Many years ago I had a Kwick Way (blue) set up for valves and a Nu Way seat cutter ... Bought both at a garage sale and used it in the shop
Old Mar 25, 2024 | 08:48 AM
Max Headflow
I've been using Neway of late, they cut real nice if you drive them with a low speed drill motor.
Old Mar 25, 2024 | 10:16 AM
CoolBreeze3646
<Snip>
It isn't, I used my dial indicating eyeball depth gauge.
The Turk
Flathead
Nov 16, 2022 04:01 PM
drm1978
EVO
Apr 19, 2020 09:22 PM
46u
Exhaust System Topics
Oct 16, 2013 12:01 PM
terrapin88
EVO
May 9, 2013 10:33 PM
chrism84
Mar 21, 2007 05:44 PM
