Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
thanks Paul, that's great to know. I'm in a smaller city of Australia so good evo bikes are hard to come by and the prices are getting higher and higher....
yes, I've had evos with the ev27 cams at 9.5-1 comp and they go well. The bottom end is my biggest worry as there is no one in 4000 miles that can rebuild a bottom end and it costs an arm and a leg in this country.
I was thinking 10-1 KB pistons with the EV46, but I'm definitely open to cam suggestions. I want most of the power between 2700 - 5000rpm
