Tappet bled down. Why do we do this
on adjustable push rods, it depends upon what is the type and outcome needed. having the lifter void of oil helps to get correct setting. the best way is to remove the lifter and take them apart and reassemble dry since doing in block where there is oil still in the galley can actually enter the lifter affecting measurement if you are not careful.
with adjustable and no spacers, adjust with plunger fully up the requires number of flats to TPI to set stroke mid range.
with limiters, you adjust with plunger fully down and loose the rod from just turning free from valve spring pressure the require TPI flats to get the required setting. i set mine to allow .030 rocker to stem clearance. i run in the solid mode with just enough clearance to quite the valve train. you must factor in the rocker ratio. ex: .001 at the lifter is .017 at the valve stem.
Then we adjust the pushrod the required amount of turns on the adjuster.
When we do this, sometimes the lifter piston goes down right away, but if the lifter is full of oil the piston in the lifter will not go down right away, instead; the valve gets lifted off the seat.
Eventually the oil will bleed out of the lifter and the valve will return to the seat.
That is why we wait until we can spin the pushrod with light finger pressure (to ensure that the valve is back down on the seat before we rotate the engine).
I've always reused the stock pushrods and tightened down the rockers with the lifters on base circle hours at the end of the cam swap. I was having a brain fart trying to figure out how these lifters got pumped up while out, lol
They actually bleed off slightly thru a lift. Why race cars use solid lifter.
To make a stock Harley quite, the cam shaft has about some degrees of rotation built into them that has a slight ram before lift just in case they don't pump to base circle diameter called the clearance.
Most usually pump up in the first starting crank also.
Most lifter I have worked with have about .200 piston travel. You want to get in the middle of that.
On my last rebuild on a Jeep motor, since the valve seats are hard, I got a local shop to grind them. They were supposed to be reliable. I supplied the new valves since stem height need to be correct since rockers had no adjustments.
Told them I would build head. They didn't listen and built it.
Only after installing rockers did I discover some rockers only had a half turn of rocker bolt before bottoming.
I ended up fixing it by facing off the rocker base.
