Tappet bled down. Why do we do this
Old Jun 24, 2024 | 11:11 AM
user 7209823083's Avatar
user 7209823083
Originally Posted by wfolarry
Wrong. That's not how a lifter works & they do rely on oil pressure not suction.
Where do you guys get this stuff from?
So the lifter would work equally well without the internal spring?
Old Jun 24, 2024 | 11:14 AM
user 7209823083
Originally Posted by Jackie Paper
The relief valve is part of the pump on an OEM TC
The relief valve is placed in the cam plate, not in the pump.
Old Jun 24, 2024 | 11:45 AM
Jackie Paper's Avatar
Jackie Paper
Thank you. I have always thought that view and about it feeding into return was on pump. I see a better display on Zipper that shows it like you say.
Guess your fighting AI on how they fill. But they just probably fill with oil to top when piston spring is holding no clearance at base circle.
So it does probably take pressure to get it there. But like you say, even 100 psi wont push it too tight at the base circle.
Old Jun 24, 2024 | 12:12 PM
user 7209823083
https://youtu.be/H-2IoJORd7E?si=ZbJQYJCPGgXPCtZq
Yeah, maybe I'm wrong about the filling, it could very well be oil pressure that lifts the plunger, but I do believe the spring assists with it too.
The point was anyway that there is not even close to enough pressure to compress the valve springs.
And regarding Al I was just super confused, I thought you were talking about AI as in artificial intelligence..
This thread as it turns out is not one of my better moments on this forum 😂
Old Jun 24, 2024 | 12:31 PM
Jackie Paper
I clarified as AI. Artificial Intelligence. Did I spell it wrong?
Note that are Harley uses roller lifters, so they don't spin like a non roller lifter.
Glenn Gorman
Engine Mechanical Topics
May 29, 2024 05:23 PM
Spencer095
17
Aug 22, 2023 08:07 PM
snake_eyes
Jan 8, 2023 02:04 PM
martin10
14
Jul 20, 2022 07:56 AM
adm
Jan 13, 2016 07:56 AM
