Chirping
Old Jul 22, 2024 | 10:05 AM
Humber's Avatar
Humber
Stage II
Default Chirping
I have a 2009 deluxe with a screaming eagle 103 upgrade. I have a steady chirping noise that starts a few seconds after start up. It seems to be in the lower front jug, not certain.
any thoughts on this matter?
Old Jul 22, 2024 | 10:16 AM
Uncle Larry's Avatar
Uncle Larry
Check your engine mounts
Old Jul 22, 2024 | 10:59 AM
Jackie Paper's Avatar
Jackie Paper
Get a two ear mechanic's stethoscope from Harbour Freight (under $10) or your equivalent to that type store and at least pin point it.
The old screw driver method is too crude and standing and listening is really hopeless most of the times. Sounds travel all over.
Especially a chirp.
Now maybe the birds sound different over there. If it seems to be a rubber mount, hit it with a silicone spray. Should go away.
Might consider replacing it if it's loose but if it's tight and you know what it is, it's fine.
PS Rod, Welcome to the HDFORUM. Only as a suggestion by me as a USER, create another new thread over in the newmember welcome area to say hello.
Hope you enjoy the ride here as much as your Harley.
Old Jul 23, 2024 | 08:07 AM
bustert's Avatar
bustert
bad cylinder gaskets will chirp
Old Jul 24, 2024 | 08:15 AM
MotoJockey's Avatar
MotoJockey
My shifter linkage heim joints would chirp a bit sometimes when the "Dry Lube" went away. Went to water resistant grease and it's much better.
Old Jul 24, 2024 | 08:19 AM
rigidthumper's Avatar
rigidthumper
Chirping could be anything from a lifter skating on a cam, failing inner cam bearing, head gasket leak, to an exhaust leak.
Old Jul 24, 2024 | 09:45 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Check your heat deflectors on your front exhaust pipe for looseness.
Does it change or go away after things heat up after 15 minutes?
jd140400
Mar 29, 2023 02:33 PM
utz
Softail Parts
Aug 21, 2012 02:50 PM
4x4Given
Motorcycles For Sale
Jun 26, 2010 11:19 PM
TurboExempt
Jun 25, 2009 02:41 PM
fireballin03
May 23, 2008 01:48 PM
