Kick back when cranking
Old Aug 8, 2024 | 04:19 PM
bustert's Avatar
bustert
yep, every time i start to get starter drag/grind/kick back = battery needing to replace.
Old Aug 8, 2024 | 04:54 PM
TriGeezer's Avatar
TriGeezer
One the battery, as they age can turn the starter but not enough torque to overcome kickback.
Old Aug 8, 2024 | 06:39 PM
Pop-pop2's Avatar
Pop-pop2
Ok, sorry for leaving some things out. Thought I had included everything. Yes, it has manual compression releases, work properly. Yes, heads are ported. Battery is new this year. No, I haven't had it load tested. It does have the stock battery cables, but connections are clean. I can make up heavier cables for it. Did not disassemble the compensator, just verified it was torqued to spec. Could be broken spring. Hate to pull it back apart, but will if need be.
I will make up new cables first.
What is the correct way to check the starter ?
Thanks for all the input.
Rcloud72
Oct 22, 2020 07:04 AM
Krazy8s
Jun 27, 2018 02:46 PM
Scrmnvtwins
38
May 14, 2015 11:16 PM
mplecha
Sep 26, 2008 03:49 AM
buick455gs
Feb 26, 2008 08:50 AM
