Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
The reason why you have really dark areas there is because the combustion temperature is really isn't reaching what it should be to be efficient.. When it does tech proper temps it won't leave that much of a deposit on the porcelain and running rich causes a cooler combustion temp. You got to remember too that the spark plug is what really cools down the combustion chamber it travels through the porcelain and up the atmosphere so don't ever put any kind of cover on your spark plug it only holds a heat in longer...
