2021 M8 114 w/53K - Borescope
Old Sep 23, 2024 | 05:01 PM
David Crowell's Avatar
David Crowell
Default 2021 M8 114 w/53K - Borescope
I recently acquired a borescope, and decided to take a look inside my bike's cylinders.
Here's a video of the front cylinder:
Rear cylinder:
This is a 2021 FLHTK with 53,000 miles. Is this normal? I think I see some cylinder scoring and a bunch of carbon. This bike is completely stock. I still have ESP. Should I try to get my dealer to do anything?
Old Sep 23, 2024 | 05:20 PM
NorthWestern's Avatar
NorthWestern
The rear looks like it ate a bit of water.
Front looks "normal" for a stock engine that has the crankcase breather feeding into the intake.
Old Sep 23, 2024 | 08:13 PM
Vec's Avatar
Vec
link for borescope?
Old Sep 23, 2024 | 10:14 PM
David Crowell
Originally Posted by Vec
link for borescope?
Amazon Amazon
Old Sep 24, 2024 | 07:16 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Divert the breather to atmosphere and use some Seafoam in the tank and ride..
Old Sep 24, 2024 | 08:34 AM
bustert's Avatar
bustert
have fun with that warranty thingy
they will consider it normal wear and tear and/.or maintenance
especially with that many miles. on the ole irons, it was considered normal for 1 qt per 500 miles, the evo is better but i do not remember their turning point.
Old Sep 24, 2024 | 06:19 PM
Max Headflow's Avatar
Max Headflow
Looks like you never ran it the limiter..
Old Sep 25, 2024 | 12:08 PM
David Crowell
Since I was there, I replaced the plugs, checked the air filter, replaced one plug wire that was rubbing on something, and got it back together.
I'm going to consider venting the breathers through a catch-can. If I do, I'll ride a few thousand more miles, and scope it again.
Old Sep 28, 2024 | 04:38 PM
JimL_15 Electra Glide's Avatar
Ride it like you stole it. That will also help otherwise a manual decarbonization may be in your future.
Old Sep 29, 2024 | 03:39 PM
xcbullet's Avatar
xcbullet
Looks like detonation on rear cylinder, thats why its cleaner. Not destroyed yet but could use a better tune.
I would ask them to look into it as its totally stock, if it was mine I would be checking injector on that cylinder .
