CAM INSTALL ISSUES
on install was the cams on their base circle prior to PR adjustment? Were they installed and adjusted correctly ?
if so , then personally don’t think you let it run long enough at initial start-up.
The dealer/shop will.
Pretty sure no damage has been done and based on the information you have provided, check for a loose pushrod as Lonewolf has suggested. Set each cylinder at TDC on the compression stroke, open the push rod tubes and see if you can spin the push rods and if there is any vertical movement. If there is, readjust the push rods and set preload at .125"
Just for ***** and giggles, a compression test will verify if the cam timing is correct. There have been many posters here that swear the timing marks on the inner sprockets were correctly aligned but a compression check tells a different story. If cam timing is off that could explain the rough idle.
If pushrods spin, no vertical movement detected and cam timing checks out, start if up and let it rattle; the noise should diminish. Whether you wait for the new tune or not is up to you but the new tune is not going to resolve the valve train noise; you can solve that problem now. Good luck.
. Have a go at readjusting the pushrods. It does take a bit for lifters to pump up. If you can spin them quicklyafter adjusting then they aren't pumped up. As for riding it home taking it easy may be safe but being a dyno guy there's nothing like a well tuned bike.
Which I doubt will happen with a downloaded map anyways.
