Runout Primary Side
Having a Dyna 2006, (bored to 98 ci), I just installed a new belt, stator, rotor and SE Compensator.
As the primary is open, I thought I might as well check the crankshaft runout on the primary side.
(I should here mention that my bike has 200 psi cold cranking compression and that the crankshaft runout is a bit of concern.)
I know runout is much more crucial on the right side, which was 0.0021” (+ gap 0.0007 = 0.0028) three years ago, but I will not open it there right now, and I thought measuring on the left side would give me an idea about the health of the crank, as well as an indication of how much runout there may be on the right side.
Anyway, the runout on the primary side is today 0.0028” as measured on the picture below:
So what is normal runout on the primary side? Well, have googled and found a text saying that the Harley service limits for crankshaft runout is 0.012” for the right side.
Now, if the service limits are 0.012” for the left and 0.003” for the right side, (the latter according to the Harley manual), can I then breath easily assuming the runout will not be more on the right side than it is on the left side? In my world, if the crank scissors, this will affect the runouts on both sides. Or do they live independent lifes?
I too wondered why you could not measure on the sprocket side, left. I never considered measuring the nut, that seems a waste of time. First it is a nut, second, lots of parts between it and the shaft.
Yes, then they had not changed it 2006. I believe I read they changed the pinion side to max 0.012" at a later point.
My thinking goes like this: If the crank has scissored it would have created major runouts on both sides. But I have no experience, so that is why I ask.
I'm not seeing the problem?
It would be good for anyone who has opened the primary to know if he could get a hint about the state of his crank and the runout situation on the pinion side by measuring the primary side.
