Leak down test
Old Apr 9, 2025 | 01:55 PM
djl's Avatar
djl
OP didn't specify displacement or any modifications but even for a stock TC88, I would have expected CCP to be about 160psi, particularly with the low mileage.
Old Apr 9, 2025 | 02:09 PM
Tommy C's Avatar
Tommy C
If the OP has an aftermarket cam in the bike, 147 psi isn't a problem.
Old Apr 9, 2025 | 02:25 PM
Jackie Paper's Avatar
Jackie Paper
The manual for it like my TCb 04 says 90 minimum.
That's a warm engine, with throttle wide open .
At 34,529 mine had 149 and 139. Most TCs in those years had moderate compression ratios 8.9-1 and run on mid grade or even regular at sea level flat lands.
That's pretty typical across the model line except the 1200 sporty at 9.7-1
Old Apr 9, 2025 | 02:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Your compression numbers are fine, no need to do a leakdown test.
A leakdown test only shows the leakage with the piston in one spot, it is more of a troubleshooting tool that an engine health tool.
The reason the piston is being forced down when you pressurize the cylinder is because the piston is not at the top of the stroke, it doesn`t have to be far off TDC for this to happen (on an airplane you can have someone hang on to the prop ).
If compression test shows low compression, a leakdown test is a good way to see where compression is being lost, but this is more useful on aircraft engines, where there are things that can be done to solve the issue without very expensive engine disassembly (on a piston aircraft engine the valves can be lapped with the heads still installed).
Another thing to keep in mind is that a compression test or leakdown test may not be telling you how the compression is when the engine is actually running.
If the engine is performing well and not consuming oil, there is no reason to look for problems.
Old Apr 9, 2025 | 04:29 PM
djl's Avatar
djl
Not saying the OPs compression numbers are a problem; just saying I would have expected 155-160 at the "near new" mileage.
Old Apr 9, 2025 | 05:45 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Thanks for the responses. I'm working on this bike because the client says that he was having throttle response issues and that he heard a valve noise. He also wanted me to go through the rest of the bike as well. I did a test ride and didn't notice anything other than he had no rear brake. The bike is all stock including the original tires and has 1603 miles. The bike wasn't stored to good, as there is rust all over but not too bad, just needs a good cleaning.
As of now, the carb is being cleaned and rebuilt. I did the compression and leakdown tests to rule out the valve noise. Took the bike for a chilly ride and nothing really stood out. Clutch adjustment w/fluid change and the rear brake needed a fluid flush. It's a solid bike just needs some TLC.
I appreciate all the responses, I was just confused on the rear cylinder leak down test.
Ride safe!
Old Apr 9, 2025 | 05:50 PM
nutsandbolts5212
My leak down tester has PSI breakdown chart for testing at 100, 90, and 80 PSI. I did 90 so I wouldn't have to change the regulator on my compressor cause its already set up for my pneumatic tools.
Ride safe!
Old Apr 9, 2025 | 06:15 PM
Jackie Paper
Ride safe!
Never seen a leak down set like you have. Does the instructions interpret that reading you got as 3%?
Old Apr 9, 2025 | 09:22 PM
tdrglide's Avatar
tdrglide
  • I hope you aren't test riding on those 22yr old original tires.
Old Apr 10, 2025 | 09:35 AM
nutsandbolts5212
I only rode in the immediate neighborhood, but I did tell him to replace the tires.
Ride safe!
