TC 103 noise after hot
Old Apr 13, 2025 | 11:11 AM
rafaa1's Avatar
rafaa1
Stage II
Default TC 103 noise after hot
Hi, I have a strange problem with my 2017 Fat Boy, Twin Cam 103 engine.
After it is very hot, a strange noise starts, as if something is scraping around the cam plate. I can't identify where the noise is coming from.
When driving and cooling, the noise stops, but when stopping at a traffic light, for example, after a certain time (1 or 2 minutes) the noise returns.
The engine has 20 thousand miles, maintenance and oil changes are up to date, currently using Motul 5100.
I attached 2 videos: one of them with the noise and the other after 5 minutes with the engine off.
Note: in none of the videos did the engine activate the EITMS.
In the "hot" video, I understand that the noise is normal. The noise appears on "very hot" video.
File Type: mp4
File Type: mp4
Old Apr 13, 2025 | 06:11 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Simple fix. Get that Motul 5100 15w50 outta there. TOO THIN!! Harley RECOMMENDS 20w50. I've got over 107,000 on my 07 Dyna. 20w50 from day one.
Old Apr 14, 2025 | 10:31 PM
JimL_15 Electra Glide's Avatar
I'm sure that you know the 15 number is for cold starting, right? The number 50 is what counts for "hot" operation. Changing oil won't do anything imo. Now if you say a 60wt as a test then I would agree with ya.
Old Apr 15, 2025 | 06:43 AM
elPrez's Avatar
elPrez
I definitely hear a metal to metal noise, could it be as simple as a heat shield gets loose as it heats up?
Old Apr 16, 2025 | 06:34 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Need to know all modifications to the motor please...
SportsterRider85
Aug 26, 2017 03:14 PM
BigMESA
Oct 26, 2013 08:08 PM
1peter
Jun 5, 2009 11:10 PM
zyepod
Oct 22, 2008 08:18 AM
mtnlvr
EVO
Apr 22, 2007 11:05 PM
