03 sportster running rough when warm
Old Apr 22, 2025 | 02:04 PM
Jordy luinge's Avatar
Jordy luinge
Stage I
Default 03 sportster running rough when warm
Hi!
a few weeks ago i did a little run on my ‘03 sportster.
after i was on a little break i started it, drove away and suddenly it started to misfire. And running really rough.
the last few weeks i’ve been trying to get it to run right. But no luck yet.
When the engine is cold it runs very well. Also starts always, cold and warm.
i’ve already replaced all the manifold gaskets (don’t leak when tested)
the coil, rebuilt the carb, adjusted the pushrods and checked for the timing.
the motor is a build 1250 S&S with 200psi of compression, and a dynatek 2000i ignition.
any suggestions will be appriciated😁
Jordy
Old Apr 23, 2025 | 03:58 AM
Jackie Paper's Avatar
Jackie Paper
Put an clip on timing light on the spark plug wire. See if you can see if it's electrical.
Welcome to the HDFORUM.
Old Apr 23, 2025 | 06:27 AM
Baird's Avatar
Baird
You may be leaving the enrichener on too long and giving the plugs a fur coat.
Old Apr 23, 2025 | 12:33 PM
marcodarq's Avatar
marcodarq
what carb, what size jets, what pipe? did it run well for a time and then change or did you do the upgrade and this is what you got when done. Please give some background.
m
Old Apr 25, 2025 | 08:27 AM
bustert's Avatar
bustert
spark plugs
Old Apr 25, 2025 | 11:28 AM
Madnss's Avatar
Madnss
Bike gets hot and doesn’t want to run could very well be the ignition is failing.
Vza
Carburetor Related
Feb 23, 2025 11:43 AM
Daybreaker
Jul 2, 2020 07:35 AM
Winweg12
Nov 30, 2016 11:49 PM
Visualsoul21
Jun 4, 2012 04:02 PM
PeterP
Jun 21, 2010 05:32 PM
