Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have a streetglide ST flhxst 2022. It has a 3030 star cam in it. When it was new , like 200 miles , they didnt change the lifters. I was thinking about new lifters. Option for feuling hp+ lifters and s&s lifter cuffs. It had now 2000 miles on it.
I want to change the lifters from above. I have SE adjustable pushrods. Thinking of running the engine hot before take those lifter cuff bolt loose. Then lifters out en new lifters in + cuffs.
