Air pressure crankcase TC96
Old May 25, 2026 | 05:58 PM
jim70's Avatar
jim70
I'm a fly boy and currently basking in the London heatwave while it's pouring rain back home. Fly back Wed .... 535kts...with 110 on the nose...but can't rush it any better.
Happy Memorial Day.
Old May 26, 2026 | 06:56 PM
jim70's Avatar
jim70
Well guys, I removed air cleaner and both small breather hoses from air filter. I started and idled bike and absolutely zero pulsating or air emitting from either breather bolt holes. Both sides. Both bolts internally clean and unobstructed. Even removed both breather bolts completely and same ditto effect. Nothing pulsating out of either bolt hole. Switched off engine and still same rush of air when removing oil cap. I can look upstream now to rocker boxes and breathers but isn't it unusual to have both cylinders doing same?
What else might it possibly be aside from rocker breathers, before I start lifting tank to access rocker covers?
Thanks all.
Old May 26, 2026 | 07:33 PM
Schex's Avatar
Schex
I can't think of anything but something wrong with #'s 34 or 35.
Seems strange both would fail together, but maybe they didn't, maybe one hardened and failed, then you started noticing the pressure when removing the dipstick after the second failed.
Maybe someone else saw this before.
Old May 26, 2026 | 09:05 PM
jim70's Avatar
jim70
Many thanks.
ill listen out on the forum before I tear into it.
Indeed bizzare both cylinders similar.
I meant to fire up my other twin cam, pull the air cleaner at idle and compare.
appreciate your help
Jim
Old May 28, 2026 | 03:53 PM
Max Headflow's Avatar
Max Headflow
You need to figure out if the air is rushing out or in. If rushing in then don't worry.
Old May 30, 2026 | 10:26 AM
jim70's Avatar
jim70
So I held a smoking incense stick near the cap and after shutting down and unscrewing oil cap, the smoke from the stick was sucked into the case immediately. So it’s a vacuum in case and not pressure. What gives now?
Old May 30, 2026 | 11:24 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Clogged breather / vent line ? Any chance the air filter is clogged?
Old May 30, 2026 | 11:46 AM
jim70's Avatar
jim70
I had pulled the filter and vent hoses off and ran bike but still same.
Old May 30, 2026 | 11:58 AM
Tommy C's Avatar
Tommy C
I don't believe that there is a problem here. Having vacuum in the crankcase is a good thing.
Old May 30, 2026 | 12:04 PM
Max Headflow
You will pull a vacuum from the filler neck if the motor stops at or close to TDC. That means the breather valves are working properly.
