O-ring question, cylinder base
Old May 27, 2026 | 03:47 PM
niv's Avatar
niv
Default O-ring question, cylinder base
Hello,
can anyone help me with the parts number for the green o-ring as pictured, at the bottom of my cylinder (2012 Softail 103).
I can’t seem to locate the correct section in the partsfinder where it would be pictured.
thanks already, niv
Old May 27, 2026 | 04:15 PM
MURPHCC1's Avatar
MURPHCC1
11273-0RING
Old May 28, 2026 | 04:55 AM
niv's Avatar
niv
Thank you! Not sure how I could have missed that one… and it turns out with Cometic MLS gaskets you are not even supposed to use this o-ring.
best, niv
Old May 28, 2026 | 11:45 AM
tdrglide's Avatar
tdrglide
You will need that o-ring for cylinder base.
You do not use same o-ring at head gasket if using cometic mls head gaskets. You still need at cylinder base
Old May 29, 2026 | 04:15 AM
niv's Avatar
niv
🙄 fair point…
Old May 29, 2026 | 06:33 AM
Jackie Paper's Avatar
Jackie Paper
Isn't it designed and built into the cometic mls head and base gaskets set?
Old May 29, 2026 | 10:59 AM
niv's Avatar
niv
Yes, but the head gasket goes between cylinder and head. The o-ring I was initially looking for is at the base of the cylinder, where there is no such gasket, just a large o-ring.
Old May 29, 2026 | 11:30 AM
Jackie Paper
Then for sure you need the Nitrile o-ring if that's what Harley specs if you base gasket is the original OEM large o-ring.
That set I show is the head and base cometic. Thought that what you had since I thought you were saying they said you didn't need the o-ring with their base gasket.
Old May 29, 2026 | 04:45 PM
niv's Avatar
niv
When I said I did not need said o-ring I had top and bottom of the cylinder confused (don’t ask).
that said, I was not able to find anything but an o-ring from cometic for the cylinder base, at least for the bore required for my 103. And with the bore-sized o-ring, I’ll certainly need said dowel o-ring as well at the base.
at the head I should be fine without, give the MLS gasket.
best,niv
Robby94
Ironhead
Apr 25, 2024 07:21 PM
SeeR
Engine Mechanical Topics
Apr 2, 2024 05:55 PM
Greasychuco
Jul 18, 2021 09:08 PM
rsscoggins
Wheels/Tires
Aug 18, 2012 02:07 PM
SteveinNKC
Wheels/Tires
Jun 12, 2009 11:25 AM
