Exhaust Gaskets
Old Jan 23, 2006 | 10:42 PM
HDF Tech's Avatar
HDF Tech
Default Exhaust Gaskets
Submitted by: springer_ (V Twin Forum) & http://www.bigboyzcycles.com/
Something that can be easily overlooked when building a performance V-twin, the exhaust gaskets. The stock exhaust gaskets have a lot of "crush" in them. They tend to crush down and block the exhaust port. After spending hundreds or even thousands on the heads, installing the stock exhaust gaskets can take away a lot of the performance gain.
We ship a set of SE performance exhaust gaskets (or equivalent) with the heads to make sure that the right ones are used.
HD part# 17048-98
I took a picture of a stock exhaust gasket used in a ported head.
The part of the gasket between the Yellow line and the Blue line is the "shelf" where the gasket sits.
The part of the gasket between the Yellow line and the Red line overlaps into the port, partially blocking it. You can see the clearly defined line of Carbon from the exhaust gasses. Also note how irregular the inside of the gasket is. That is the part that gets "Crushed" into the port.
This is a picture of a performance exhaust gasket that was removed from a ported head also. It is a good comparison to the stock exhaust gaskets. It is easy to see that there is no carbon line like the stock gasket. It is a good representation of how little it blocks the port compared to the stock gasket.
Old Apr 17, 2010 | 10:46 AM
MHenriques's Avatar
MHenriques
6th Gear
Default What about these Cometc gaskets?
What about these Cometic copper and steel gaskets on the picture attached ? Any comments on which is better?
Thanks
Mauricio
hfp3030
May 1, 2012 09:43 AM
shaker
Exhaust System Topics
Apr 27, 2011 05:53 PM
JakesDad1
Mar 25, 2011 09:55 AM
mastery
Jan 28, 2011 12:15 PM
springer_
Jan 22, 2006 12:56 PM
