Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
i dont think a stock engine needs it, the compression is low enough it can turn over without problem.
A pretty extensive google search brings up multiple threads on many forums of people who had to ADD a compression release to a twin cam that they bored to 109 or more CI. so that also shows it doesnt come stock.
