Starter trouble
Old Nov 1, 2009 | 03:15 PM
Wampuscat's Avatar
Wampuscat
Default Starter trouble
Friday morning I got on my '94 FLSTC to head down to Galveston, Tx for the Lone Star Rally and OhShit!!! I hit the starter button and CLICK... CLICK... Then it turns over like nothing was wrong and fires right up. After that, all weekend it would fire up. Sometimes it would hesitate, sometimes it would crank right up. Do I need to change my starter out or is this problem like a bad bendix on an old Ford? Is this a hard job or a simple one for somebody with mild wrenching skills?
Old Nov 1, 2009 | 07:37 PM
asm481's Avatar
asm481
Clean your battery cable connections. Sounds like a bit of arcing is heating the cable and making contact. remove, clean, reinstall.
Old Nov 2, 2009 | 06:55 AM
sqdealgeorge's Avatar
sqdealgeorge
How old is the bat ?
Old Nov 2, 2009 | 09:14 PM
Wampuscat's Avatar
Wampuscat
I bought the battery at an HD shop about a year ago. The cables are tight and have no corrosion. The charging system was repaired about 10 months ago.
Old Nov 8, 2009 | 06:37 AM
chunky's Avatar
chunky
Having the same problem basically. I went to the store and the bike cranked just fine, but it all ways has the hesitation before it starts. Anyway I came out of the store and hit the starter and nothing. Tryed to jump it off and still nothing. Any suggestions would be greatly appreciated.
Old Feb 3, 2010 | 12:28 PM
hornhonker's Avatar
hornhonker
Did the starter relay pull in when you hit the button ? If not check fuses. Sounds also like a compression release would be in order (I wonder why the don't fit them in all HDs ?)
cajun1957a
Shovelhead
Sep 28, 2014 11:15 PM
Ulflangkamp
Jul 4, 2012 11:43 AM
Victour
Jun 14, 2011 12:45 PM
Derv
Jun 29, 2010 01:04 PM
Wampuscat
Nov 1, 2009 11:05 PM
