Mods Technique For Quiet Pipes
Old Jul 6, 2010 | 10:11 AM
Nisbet's Avatar
Nisbet
Default Mods Technique For Quiet Pipes
My Wide Glide has the super quite mufflers.
I wanted a bit more rumble and modified them as follows:
Got a 1-1/4 inch wood dowel X 10 inches long;
Bought a long drill (1/4 dia X 12 INCHES LONG);
Drilled a 1/4 inch hole lengthwise thru center of dowel;
Inserted dowel into muffler (Fits inside baffle);
Inserted drill thru hole and drilled hole in baffle, centered by the dowel;
Got a 5/8 inch drill and a drill extension;
Inserted drill so it engaged 1/4 inch hole in baffle and drilled to larger dia;
Result: You will get excellent improvement in sound, and size of hole will dictate how much loudness you get:
1/4 inch hole will give very small increase of sound:
3/8 inch hole will give small increase of sound:
1/2 inch hole will give medium increase of sound:
5/8 1/4 inch hole will give larger increase of sound:
3/4 inch hole will give moderately large increase of sound but substantailly less than streight pipes.
There are techniques to completely remove the baffles, but that will produce extreme loudness and in many states, running without baffles is illegal.
Thanks,
Bob Nisbet
Redstone Arsenal, AL 35898
Jimmyess333
Jan 22, 2018 10:11 PM
jphillips
Jul 18, 2014 05:22 AM
hamdizle
Apr 9, 2012 10:26 PM
Nisbet
Jul 7, 2010 03:32 PM
acollett23
Aug 31, 2008 10:49 PM
