Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have about 600 miles on a 103 kit where it touched up the heads and valves, added Dave MAckie Cams and a PM Super Gas Air Cleaner. I am noticing a lot of butterfly noise coming frmo the intake manifold that I did not hear before the upgrades. I realize its sucking more air due to the modifications but should it be making a lot of noise? Thanks Chris
