Inconsistant idle speed
Old Apr 19, 2012 | 08:51 PM
summer cruisin's Avatar
summer cruisin
Stage I
Default Inconsistant idle speed
I have a 2006 Dyna Wide Glide, after getting up to operating temp. (approx. three miles) the engine starts to buck / sputter around 2200 rpms. There is no check engine light, etc. If you speed up it appears to clear up, it is most noticable around 2200 rpms. It acts like a fuel problem to me however it is fuel injected. I just installed a new battery as the other one was the original and I am getting 14 volts at an idle running. This problem existed before changing the battery, I actually thought that the age of the original may have been the problem with all the components on the bike (fuel pump, injectors, lights, etc.) After it is up to temp. the idle does not stay steady also, it ranges between 1,000 to 1,500 rpms. Any ideas??
minar
Sep 26, 2018 04:04 PM
dj skuzzy
Apr 5, 2015 05:18 PM
Anoldbastard
Jul 25, 2013 02:06 PM
rjmac53
Nov 20, 2006 08:15 AM
HDF Tech
Jan 7, 2006 06:12 PM
