Starter
Old Jul 2, 2012 | 08:17 PM
marsanro's Avatar
marsanro
Stage II
Default Starter
Bike makes steel on steel clank when trying to start is it low battery or bad starter
1990 Electra glide
Old Jul 6, 2012 | 08:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
We can`t tell you what condition your battery is in...
How old is it? You can have it checked at an Auto Zone parts store, or similar auto parts store.
Caution: Disconnect the battery before doing any work.
Make sure all electrical connections are clean and secure.
A single loud metallic sounding click from the starter, when the button is pushed, usually indicates that the contacts inside the starter solenoid are not making good contact.
A rapid clicking sound while holding the starter button in usually means the starter is not getting enough power, usually caused by a weak battery or poor electrical connections.
You can remove the cover from the end of the solenoid and see the contacts (remember to disconnect the battery first, even before you remove the chrome starter cover).
You can get a solenoid rebuild kit from a Harley dealer, but you can get the same parts for much less coin from any starter/generator/alternator repair shop.
A starter shop can also rebuild your entire starter for way less money than it would cost for a new starter from Harley.
These starters are common automotive units, any decent starter shop will be very familiar with them and have parts in stock.
My awesome
Oct 17, 2014 10:26 AM
irydasteelhorse
EVO
Feb 22, 2014 10:00 PM
pd76
EVO
May 7, 2012 07:22 PM
davewear
Apr 10, 2007 04:47 PM
lennox5024
May 23, 2006 02:21 PM
