will it fit
Old Feb 6, 2013 | 08:56 PM
bigfluff78's Avatar
bigfluff78
Stage I
Default will it fit
can the top end from a 2007 street glide fit in a 2002 flht
Old Feb 13, 2013 | 11:47 AM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF.
The 2007 bike is a TC96 and your 2002 is a TC88 and those parts AFAIK are not a straight swap. You will get better replies if you post in the Technical forum, where our engine gurus live. If you take a look around over there you may even find an answer yourself.
Old Feb 14, 2013 | 10:00 AM
46u's Avatar
46u
Should if you get different pistons or use the ones in your 88. 96 and 88 have the same bore only difference is the stroke. I have never done it but my educated guess is they will. I am looking at a 08 top end for my 88 only real difference is the 08 up has the two holes above the exhaust mount for the later frames with the front engine mount.
LeeC_Mo
Oct 9, 2019 02:53 PM
SudHD
Sep 4, 2013 12:22 AM
hogbag07
Aug 16, 2008 05:19 PM
beary
Feb 19, 2008 01:09 PM
IceHeritage
Dec 30, 2007 10:38 AM
