starting a neglected Ultra Classic
Old May 20, 2013 | 11:02 AM
agood's Avatar
agood
Stage IV
Default starting a neglected Ultra Classic
I inherited an 06 Harley Ultra Classic that was serviced, filled with fuel, and parked under a carport about 2 1/2 years ago near Houston, it has not been started or ridden since. Are there any special things I should do, other than a new battery, before hitting the start button?
Old May 20, 2013 | 05:38 PM
barchetta's Avatar
barchetta
Well, if you dont know if the fuel was treated Id drain it.. refill.. not sure how you could get the FI lines flushed though.. you may need to pull the plugs and turn it over until its cleaned out.. also, I personally, would squirt some engine oil in each chamber.. maybe a teaspoon.. thru the plug holes.. I believe you would need to ground the plugs if you turn it over with plugs removed or else risk damage to ignition..
I could be wrong about all of the above but since no one weighed in....
Houston is an extremely humid environment.. I would strongly urge you to dump some oil in each plug hole.
Old May 20, 2013 | 05:42 PM
rooti's Avatar
rooti
Check the spark plugs, new battery, drain and refill fuel...it will start right up
Old May 20, 2013 | 05:49 PM
asm481's Avatar
asm481
Replace tires
tn_popo
Feb 26, 2019 03:59 PM
Plumbwader
EVO
73
Oct 5, 2015 08:18 PM
WestTexasRanger
Exhaust System Topics
16
Sep 17, 2012 10:57 AM
ranger_blackhat
Oct 19, 2008 11:40 AM
ckamin
Mar 25, 2007 05:11 PM
