heed help pushrods 1979 shovel
Old May 19, 2013 | 05:21 PM
shaneballance's Avatar
shaneballance
Default heed help pushrods 1979 shovel
ok i have a 1979 shovelhead 1340 fatbob,i took pushrods out ,removed hydraulic lifters,took the lifters apart cleaned them out no oil,now i have dry lifters..pushrods back in turned them to bottom out then back 1 1/2 turns.....my ? is why do i still have valve ticking?do under stand it?did i do it wrong?wtf....need help
Old May 19, 2013 | 05:24 PM
ronherman's Avatar
ronherman
get rid of them! put in the S&S solid lifter kit! much quieter!
Old May 19, 2013 | 05:49 PM
shaneballance
but i will have to get a different cam right?,,,did i adjust them right?
Old May 20, 2013 | 05:51 PM
barchetta's Avatar
barchetta
Your oil galleys could be clogged.. not cool. I would verify they pumped up before I went forward with solid lifters.
If they dont pump up.. Im not sure how to deal with the oil passages cept to try some engine cleaner..
If you put solids in, and you dont have lubrication, again, not cool.
Im assuming your 1.5 turns is the correct spec of course.. and you were sure they bottomed.. Did you check for wear on the lifters?? Youd have to mic them I would assume...
And I do not think you need a different cam to go solid.. Just be prepared to possibly adjust them often.
Old May 21, 2013 | 12:55 AM
shaneballance
When I take the lifter apart there is oil in them, my first harley , I work on jap bikes a lot but first for harley. What is a galley?
SportbikeCO
Engine Mechanical Topics
Jul 20, 2014 09:11 PM
V_twins
Shovelhead
26
Apr 17, 2014 10:26 AM
Mascman
Exhaust System Topics
42
Aug 13, 2013 06:27 PM
TO34
Mar 4, 2012 10:10 AM
WEBBiker
Mar 24, 2007 02:02 AM
