drive belt
Old Sep 15, 2013 | 07:21 PM
sidetrack's Avatar
sidetrack
5th Gear
Cool drive belt
I removed the inner primary case and the swing arm now installed the new belt and the swing arm what do I torque the swing arm bolt to and the rear axle bolt and the inner primary case and the clutch basket and the compensating sprocket and the starter bolts and the jackshaft and the primary case cover any ideas where to find these torque settings
Old Sep 18, 2013 | 09:18 AM
grbrown's Avatar
grbrown
They are in the factory service manual! I'm surprised you started this work without one. If you don't have one, also get the belt tension tool.
Old Sep 24, 2013 | 04:48 PM
46u's Avatar
46u
First thing you do if you are going to work on your bike is get a factory manual. All so make sure you torque your clutch basket properly or you will have some major problems if it is too low or too high. I torque just about everything on mine and customers. I cannot help you as I have no idea what year and what model you are working on. BIG differnce on 2002 and up rear axle torque then the 2001 and lower!
Blk/Wht/andChrome
EVO
34
Oct 30, 2018 06:03 PM
509Rider
Jun 15, 2015 01:49 AM
Very High Plain Drifter
Jun 14, 2013 10:53 PM
AlleyKatt
Nov 10, 2009 06:30 PM
janiharley
Oct 24, 2009 02:59 PM
