Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Biggest fear with a lifter is them shedding the roller's needle bearings, which basically creates a hailstorm in the cam chest. That's never a good time when that happens.
Beaucoup' reported cases of just that with the HD "C" lifter, mostly in the CVO 110"ers.
Scott
That's not an issue, in and of itself, in fact, it may be a different lifter each time depending on which one(s) are loaded when the engine stops rotating.
