Head problems
I got a great deal ( well I think so anyways) on a 2004 Sportster 1200 custom.
reason I got it cheap was because it lost compression in the rear cyl.
i figured if nothing else i could part it out..
so today I tore the top end down and found that the reason it lost comp. was because the exhaust valve seat dropped out a bit. At first i thought it
missed the piston but after looking closer I see that it did tap it just a tad I will try to load a pic to show. so I know that I will have both heads rebuilt
but my question is should I go a head and replace the piston due to the contact?
and is the one head even serviceable?
Sorry for such a long post.
Any advice is welcomed..
Oh and the bike has right at 30K miles
shiny part on the right is where it touched
and of course you can see where the valve seat dropped
Also what top end gasket set should I use? the HD dealer of course said to use all HD stuff
What do you all think it will run to do everything, if I can stay under $1000 i will be happy..
- Replace the buggered piston and piston pin. No need to do both pistons and so long as the new one weight's the same as the old you will be fine.
- Get an oversized valve seat installed. I would also be replacing the valve as well, as if its touched the piston at all then it could be bent or weakened.
- Thats about it....replace the gaskets (HD, James or Cometic are all good brands). I like the MLS type for the heads as they seal better.
- Then ride the pants off it...And do not forget to wind up the rpm once in a while...lol
Bead blast the pistons, have the fitment measured in torque plates and if within specs, new ringsk, light hone to break the glaze and put her back together. Have heads worked by BigBoyz or your porter of choice and have the valve issue addressed as part of that package. Some gaskets and oil and you are back on the road. JMHO.
I will call BigBoyz tomorrow also to check there prices.
All im looking for is a good job and not to have the fastest Harley in town..
here is the picture of the cylinder, absolutely no scratches or grooves. on the right side of the pic. is just oil on the side wall that looks funny..
