95 Electra glide overheating
Old Apr 10, 2014 | 07:14 AM
ElectraGlide101's Avatar
ElectraGlide101
Stage I
Default 95 Electra glide overheating
Hi folks this is my first post on the forum hoping for some good advice. Im working on a buddy's 95 Electra Glide, the rear cylinder is running noticeably hotter than the front cylinder, to the point that it keeps burning the intake gaskets. He has had the top end rebuilt at a independent shop to try to fix it but no luck. Also the idle is so low it almost will stall im not sure if this is related to the problem or if it just needs a hot cold idle adjustment. any advice would be greatly appreciated thank you.
Old Apr 10, 2014 | 09:30 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Engine temp/low idle could be timing related, ie, retarded timing.
I'd start there.
Scott
crazydawgs
EVO
Apr 4, 2015 05:46 PM
GLIDE_RIDER
Aug 27, 2012 12:42 AM
GLIDE_RIDER
Aug 26, 2012 09:05 PM
zz rocker
Oct 29, 2010 10:29 PM
zz rocker
Exhaust System Topics
Oct 29, 2010 05:45 PM
