110" case bore
Old Apr 26, 2014 | 08:39 PM
07fsxt's Avatar
07fsxt
Default 110" case bore
Do I need to case bore a 110 to get 120 internals to fit?
Old Apr 26, 2014 | 09:16 PM
qtrracer's Avatar
qtrracer
I believe the 4.060" cylinders have a bigger spigot than the 4" cylinders. Plus the crank needs to be changed to a 4 5/8" stroke version.
Old Apr 27, 2014 | 10:51 AM
07fsxt's Avatar
07fsxt
Thanks
Old Apr 27, 2014 | 03:45 PM
wurk_truk's Avatar
wurk_truk
Case boring will not work out very well on 110s. 110s use an o-ring for base cylinder seal. That o-ring is already next to the studs. Bigger bore takes a base GASKET, and with a 110, all of the available real estate is gone, because that block was originally o-ringed. It can be done, and is done regularly, but oil leaks, etc are a common occurrence. Hell, even older 110s had oil seal issues. I do NOT recommend going bigger with a 110.
Old Apr 27, 2014 | 07:56 PM
07fsxt's Avatar
07fsxt
Thanks, just the kind of info I was looking for.
Old Apr 28, 2014 | 05:57 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We have converted probably 2 dozen 110" engines to accept the spigot bore ID of 4.322" for S&S 4 1/8" cylinders, building 124"ers.
No issues with those.
Scott
Bagger_Vance
Engine Mechanical Topics
87
Jun 6, 2015 03:24 PM
jsbridgew
EVO
23
Nov 15, 2012 08:11 AM
bdyson250r
Exhaust System Topics
Dec 27, 2010 12:42 PM
valkal
Jul 25, 2009 09:47 PM
King Cobra
Mar 6, 2009 12:56 PM
