rocker gasket
Old May 17, 2014 | 07:38 PM
tyson.hayes87's Avatar
tyson.hayes87
Default rocker gasket
Ok i have tried searching everything and have found a lot of useful info on the tc88 but haven't found the answer i am looking for. My rocker gasket has been leaking so i tried checking the oil first and broke my dipstick. All said and done had enough money to buy the gasket and the dipstick but not a manual. Now i have gotten the old gasket out and am ready to put back in. Now for the question i need the answer to does the gasket go in dry, oiled, or does it need rtv? thank you all for the info i am sure you can give. and yes i will be buying a manual next week but there is way too good of weather a head to leave her in the garage apart. Second question what manual is the best? haven't heard too many good things about the clymer but all advice is good.
Old May 17, 2014 | 07:48 PM
fidel's Avatar
fidel
Always dry clean it first
Old May 17, 2014 | 07:59 PM
tyson.hayes87
thank you that is what i thought but i was second guessing it but thought it was way too much time and pain to get it off again.
Old May 17, 2014 | 08:15 PM
tyson.hayes87
Now what plugs would you run? Since mine have burnt oil all over them. Had champions
Old May 19, 2014 | 07:53 PM
Uinseann Di Simone's Avatar
Uinseann Di Simone
I've used both, HD & Champions, no noticeable difference.
Old May 19, 2014 | 08:10 PM
tyson.hayes87
Thanks good to know.
flicksport1200
Engine Mechanical Topics
Sep 9, 2014 04:36 PM
flat4fan
Aug 23, 2012 08:45 PM
izzyfutch
Ironhead
Mar 15, 2011 09:28 AM
southside721
Sep 19, 2008 08:52 AM
kelton3
Apr 11, 2008 10:08 AM
