oil leak question
Old Apr 10, 2008 | 04:43 PM
kelton3's Avatar
kelton3
Default oil leak question
I have a very small oil leak between the rocker cover and cylinder head, I'm assuming I have to have the gasket replaced. This causes about one drop of oil after a ride, it doesn't seem to be getting worse. My question is this: Is this leak a common problem and do people just kind of put up with it until it gets worse? Also could a novice mechanic (me), replace the gasket?
Thanks for all the help.
Old Apr 10, 2008 | 05:04 PM
Biker Trash's Avatar
Biker Trash
Default RE: oil leak question
Easy as pie to replace. Just need allen wrenches for the rocker boxes. It's a rubber gasket. The tank will need to be removed.
Old Apr 10, 2008 | 05:10 PM
kelton3's Avatar
kelton3
Thanks! I have a service manual to help me out too.
Old Apr 10, 2008 | 05:11 PM
Biker Trash
Kelton, You're set! Take your time and you'll be fine!
Old Apr 10, 2008 | 08:15 PM
drum412's Avatar
drum412
The lower rocker gasket will be fiber or metal.........The fiber gaskets are known for failing, and have been replaced by metal gaskets for the one that goes between the lower rocker and head. The upper rocker gaskets are rubber. All of which are pretty simple to replace, just make sure the sealing surfaces are cleaned up well before putting the new gasket on.
Old Apr 11, 2008 | 10:08 AM
WVHogRider's Avatar
WVHogRider
ORIGINAL: drum412
Yep....Just did this again lastnight. Piece of cake. Just follow the torque specs.
cskarns
EVO
14
Apr 11, 2018 07:15 PM
Shackleford
Nov 5, 2012 01:03 AM
04RoadKing
May 6, 2008 06:43 PM
kelton3
Apr 14, 2008 11:41 AM
johnny1966
Oil Archive (no new posts)
Nov 8, 2007 04:22 PM
