Advancing and retarding cams
Old Dec 23, 2014 | 07:40 PM
mlemay's Avatar
mlemay
Speaking of questioning things and exploring options . . . How many degrees would be advanced or retarded on an S&S gear drive by installing it one tooth ahead or behind?
Old Dec 24, 2014 | 07:01 AM
prodrag1320's Avatar
prodrag1320
WAY too much
Old Dec 24, 2014 | 08:51 AM
BVBOB's Avatar
BVBOB
The reality is that with the twin cam motor and a chain drive setup you can only advance or retard both cams, the front may already be on and the rear not etc. What I will add is with the amount of aftermarket cams available you should never have the need to change the degree of a cam. If you are doing it because you may build bigger later than you are probably comprising the present and the future build.
Ben E
Sep 2, 2020 11:51 AM
The LOWRIDER*64*
Sep 12, 2013 08:09 AM
jad
Exhaust System Topics
11
May 8, 2011 06:46 PM
jfroehler
15
Oct 19, 2010 07:18 PM
HOGWYLDPR
Apr 9, 2007 08:55 PM
