Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I've purchased a 103 SE Stage 4 "Race" kit for my 2010 RG currently with only Air Cleaner & Muffler upgrade. I do mostly 150-600 miles a day. I the mountains I sometimes have to drop 1-2 gears just to keep up with the speed limit. I got a really good deal on the kit which is why I bought it. I am concerned that it may be "too much" for touring. If you are running this kit, I would love to hear from you. Thanks in Advance
I've been running the 103 Stage IV in my 2009 SG since I got it. I understand they have changed the cams included in the Stage IV kit. I believe I heard the cams were a 259E. My Stage IV came with the SE 260 cam. It didn't help low end at all, but ran like a banshee from 3200 - 6000 rpm. So, I changed it out for a TR-625 by TR Performance. I love this configuration. You won't regret upgrading to the Stage IV.
You didn't say which exhaust you were planning on. I went with a D&D Fat Cat 2 into 1. That was the best decision I made overall.
I think you will be disappointed and constantly downshifting; the 259e is not a touring cam. A friend recently installed that kit in is 2014 Breakout and was very disappointed. The motor was dealer tuned and he had a "real" tuner re-tune the motor and rideability improved but he is still looking for more torque in the lower rpm range. He is replacing cams with S&S 570s and is also considering installing a 30T trans pulley as he would like to see 10% lower final drive.
Personally, I would avoid the kit and talk to one of our forum builders like Hillside or VTwin Performance to put together a touring package with mild headwork, more compression and a good cam set. Should save some $$ and peformance will be much better. JNHO.
I would just like to say, in response to djl's post, that I just can't agree enough that another cam other than what they offer in that kit is necessary for touring. I can't stress that enough. A great cam for that engine at a CR of 10.5 is the TR-590. What I cannot agree with is the thought that this can not be a great touring configuration. My bike with its current configuration is living proof. A lot has to do with the exhaust you choose.
I did not imply that the "kit" could not be a good touring configuration. I did say and very clearly that the 259e cam was not a touring cam; just wanted to clear that up. However, I still believe that an aftermarket including bored OEM cylinders fitted to CP, JE or Wiseco pistons, mild headwork and good exhaust built around the right cam set would be cheaper and produce better results than the SE 103 Race Kit, but that is JMHO; each to his own.
Completely agree on the importance of the exhaust. A local and well known tuner has been seeing good results with the D&D Fatcat (not the Boarzilla) and the Bassani Road Rage II. This tuner does a "dyno day" monthly every second Saturday and sees about every exhaust system on the planet and sees consistently good performance from those two systems in built and Stage I motors.
A 107" combo geared towards touring, with pupose-oriented cams and even mild heads as djl has mentioned, will eat the Stage IV thingy for lunch, for less.
Scott
Scott
No doubt that's true. However, one thing I learned when doing the build on my heritage is that going outside the HD line probably means they will no longer be prepared or willing to handle your engine mechanical issues. If something serious happened to my motor, I'm not sure what my options would be short of getting a new one. It's not easy finding an indy shop when you're out on the road that can do hi performance work.
So an HD set-up like the Stage IV may be yielding less performance, but at least I know if something happens when I'm out touring that I have a decent chance for a fix because you can't swing a dead cat without hitting a harley dealer it seems.
I really appreciate all of the replies. I already have the kit, so... My biggest concern was drivability issues the aggressiveness of the 259E Cam for touring. I realize that the 259E cam was not designed with touring in mind, I believe it was to address "issues" of the 260 used on the street.
I also scored a complete SE 2-1-2 exhaust. I am contemplating removing the cat just to cut down on the heat. I am also replacing the cam plate, bearings, oil pump, lifters and rockers (with rollers), and air cleaner.
