Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Man thats why i tell you the stage 4 race kit does all of the above, none of this oh what if i put this cam in with this compression and heads, builder down the road said this, one up the road said do it this way
Plenty stage 4 out on the ride, 2-up, touring, solo thrashing it, sunday latte run, anything
Thanks
Mirrmu
There's definitely less headache making a decision that way.
Yo want your cake and eat it too, ain't gonna happen. Get yerself some S&S lifters, pushrods and an Andrews 48 and a good tune, Super reliable. Go with a 30 tooth Baker pulley and a new belt, that's a big mechanical advantage and also totally reliable.
Its not set in stone at this time. I picked the Andrews 57 and she doesn't like much compression (should have picked one that could go up to a 10.2 - 10.5.) Andrews recommends "Minor Headwork" ( and again should have picked a cam that could do more headwork.)
So to answer your question..... I am having at least a minimum of a Hillside stage 2. Possibly more depending on Scott's advice. Asked his advice of shaving the heads a little to get compression up around a 10.1 (believe that's the recommended max on my cam.)
I may have him set the heads up just in case I want to replace this cam with a bigger one lmao
Static CR is just number; doesn't mean anything. Corrected or dynamic compression is what the motor sees as well as CCP. Scott knows how far to push the envelope with the 57 or any other cam to get the most out of the cam. Don't worry, you will like the 57; a nice cam for your motor.
