sprocket shaft install 1994 sportsta
Old Aug 10, 2014 | 05:46 AM
jamespedro28's Avatar
jamespedro28
Default sprocket shaft install 1994 sportsta
Hi can some one explain how you are to get the endplay shim and the lock ring in between the left and right hand bearings on the 1994 sprocket shaft as it states in the clymer 1991/2003 maitanance manual because it looks like there is only enough room for the lock ring witch is positioned with the opening to the oil hole.I'd be great full for any advice.
HDF Tech
Jan 23, 2013 07:13 AM
jsbridgew
EVO
Jul 6, 2011 09:40 PM
harleyhorn
Exhaust System Topics
Apr 14, 2010 09:04 PM
49pan
Panhead
Feb 19, 2010 06:33 AM
mk2007
Ironhead
Jun 9, 2009 10:02 AM
