Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So my wife wants to keep up with my new 107. I have 2 questions. Is the 48 appropriate for a light dyna?
Should i use my extra screamin eagle t/body thats hogged out to 52mm 4.9 injectors or run the stock 46.no plans on head work.
2008 dyna fatcat pipe pc3 tuner stage 2 big sucker air cleaner
A lot of dyna riders with the Andrews 48. Mostly a lower rpm performer, but should be a nice upgrade. Up to you on the tb, probably not too necessary - the bigger tbs really start helping at higher rpms and you are looking at a low rpm cam.
I agree from what I have read, no real need for the larger TB. How did that 107 turn out, any numbers?
It wasnt world breaking # but on the light dyna it feels like you are going to get ripped of the seat at any moment.
I came in at 106hp 114 tq.
that was rev perf 107 with heads tman 590 cams pc3 and 52mm tbody.
If I dont use my other 52mm intake any takers? 4.9 injectors 360$ shipped. NOT FLY BY WIRE.
48, new inner cam bearings, retune and all should be good; no need for larger T/B. However, it will take more than a set of 48 cams for her to keep up with a built 107"er.
Your 107" build is very similar to mine and the results too. I hope to improve on my build with an exhaust swap - want to put the D&D Fat Cats on and retune, maybe around Feb or March...
I hear great things about the 48's as just a cam upgrade. Don't add the TB because w/o doing headwork and enlarging your intake runners your TB will be bigger and make a step going against the air flow into the smaller diameter head runner. Won't add power, instead will only disturb the flow.
