Possible 107 build
Old Sep 2, 2014 | 10:07 AM
djl's Avatar
djl
98"; why stop at 95" when the additional 3 cubic inches are free? 98", good headwork, the right cams (TMan 590 or 600SM), good exhaust and tune will see 110HP/115TQ. If you want more than that, spend the $$ to split the cases and go big but if you take that leap, go BIG; don't stop at 107", go 117". You have to buy cylinders and pistons and machine cases to go to 107" which you would also have to do for a 117"; the added cost of the crank is the additional cost which is marginal since you will be spending $$ to true, balance and weld the 4" crank anyway. Hoban Brothers (AKA Darkhorse) will charge $500 to true balance and weld your 4" crank, or sell you their worked 4.375" crank also trued, balance and plugged with their rods for $1500. So at the end of the day, it will cost you about $1000 more to go 117" as it would to go 107" and believe me, there is a world of difference between the two.
ebeattie
May 19, 2013 06:43 PM
Billdoe
Exhaust System Topics
14
Jun 27, 2009 03:11 PM
SC-Longhair
19
Mar 1, 2009 05:52 PM
simpkinst
Feb 12, 2009 02:45 PM
harris48cars
Feb 22, 2006 08:57 PM
