Intake valve ot opening
Old Sep 15, 2014 | 11:16 AM
pest889's Avatar
pest889
5th Gear
Default Intake valve not opening
I was riding through town, and my bike started running on one cylinder... after messing around a lot I took off the intake and can see the intake valve is not opening and closing when I crank the engine... anyone know whats can cause that? There isn't any noises or anything....
Could it have gotten hot and burnt it closed kinda thing? hydraulics would let it stay there? I don't know much how the top end works....
113 Evo Ultima
near new
Thanks in advance
Old Sep 15, 2014 | 12:32 PM
djl's Avatar
djl
Check the valve train from the cam lobe to the rocker arm and you will find the problem.
Old Sep 15, 2014 | 01:21 PM
pest889's Avatar
pest889
5th Gear
I took off the push rod covers and the intake push rod is off to one side.... looks like the lifter is buggered ill change them both out....
Old Sep 15, 2014 | 01:38 PM
pest889's Avatar
pest889
5th Gear
what might make the lifter break?
Old Sep 15, 2014 | 01:45 PM
djl's Avatar
djl
Adjustable pushrods?
Old Sep 15, 2014 | 02:19 PM
pest889's Avatar
pest889
5th Gear
ya they are adjustable. could it have slipped off or something from being out of adjustment?
Old Sep 15, 2014 | 03:06 PM
pest889's Avatar
pest889
5th Gear
ok I took off the top cover and the rocker arm is broken where the push rod fits in.... that's why the push rod was **** eyed....
Update:
Changed out the rocker arm running like a top! Better than it was from new! I think it was cracked from the factory and it slowly tore off till the valve stopped opening all together.
swhitinger
Nov 5, 2013 04:27 PM
Born2cure
May 30, 2012 12:35 AM
dan61t
Apr 24, 2012 07:24 PM
Frito Bandito
Ironhead
Feb 26, 2012 07:33 AM
DesertLord
Exhaust System Topics
Apr 18, 2005 09:44 PM
