Question on SE Adjustable Pushrod Installation
Need a sanity check on this please. Just finished installing the SE adjustable pushrods per the instructions. My question: if the pushrods have been properly adjusted, are all four pushrods supposed to turn freely at the same time? Or should only two pushrods turn freely when their tappets are at the lowest point, and the other two won't turn because those tappets are at the highest point and basically under load? Wondering if I need to re-do the adjustment so that all 4 pushrods turn freely at the same engine setting....
The pushrods if adj properly should rotate somewhat tight when the cam is at the lowest point Make sure you have the lifters pumped up (ask us how if need be ) Do one cylinder at a time Watch the pushrods move up then down to the bottom travel at this point the rod should rotate after a few minutes say maybe 5 minutes or say after one beer
Finished my project a couple of weeks ago (EV27 cam, SE pushrods, "B" Harley lifters, inner cam bearing, chrome lifter blocks, etc.). Took it for a short test ride before the WX went to ****. Noticed it's running a lot quieter and has a broader power band. Better acceleration. Need to put more miles on it, but the initial impression is real good.
PeterV
Engine Mechanical Topics
07-10-2018 10:15 PM
2001, adjustable, adjustment, davidson, evo, harley, install, installation, instillation, push, pushrod, quicky, rod, se, sportster
