Top engine adjuster ,how to
Old Sep 23, 2014 | 10:50 PM
johnod's Avatar
johnod
Default Top engine adjuster ,how to
Going to try and align this thing tomorrow 97 flhtcui.
Is there a trick to getting at the top adjuster, doesn't seem like much room there?
Old Sep 24, 2014 | 09:35 AM
grbrown's Avatar
grbrown
I did mine several years ago but honestly don't recall. Replaced the scruffy originals with True-Track ones as part of an upgrade/refresh.
Old Sep 24, 2014 | 09:54 AM
nyokie's Avatar
nyokie
Id probably pull my tank? Not that bad of job, gotta drain cause front cross over tube, or may try unbolting tank and putting a block under rear tab to get it up out of way for a few. I do that method to work through top of carb to adjust, only takes a few minutes
Old Sep 24, 2014 | 09:57 AM
Schex's Avatar
Schex
talks about the top adjuster at 13:20 ,
Old Sep 24, 2014 | 10:18 PM
johnod's Avatar
johnod
Got it done, thanks.
Old Sep 26, 2014 | 09:39 PM
98glider's Avatar
98glider
My dyna has only the top adjustment only so basicly I only use that correct. Thanks, that would only do the tire in the back
Andy Tucker
Powdercoat & Paint
Jun 8, 2019 06:20 PM
cggorman
May 31, 2017 01:12 PM
desert drifter
Dec 16, 2010 02:28 AM
trozenhorse
Nov 21, 2010 09:33 AM
