Help Tank won't drain :(
Old Nov 20, 2010 | 02:36 PM
trozenhorse's Avatar
trozenhorse
Question Help Tank won't drain :(
Started the winter project. Already a few twists and turns. Head bolt stud problem and now today the tank wont drain.
Ran the bike turned the fuel line off, let it run until it stalled. Removed the carb and set it up to drain the tank today. Connected a plastic tube to the end of the tube that came off the carb and into a 5 gallon tank, turned it to reserve, nada, turned it on, nada, tried sucking a little on it, nada...tasted like chit!
Any ideas or guidance would be appreciated. Thanks everyone. Its time for a drink, outside of that, i stripped the bike down quickly !
Old Nov 20, 2010 | 02:40 PM
HOTLAP's Avatar
HOTLAP
Some petcocks have a vacuum line so fuel will only flow when the engine is running, try sucking on that.
Or you can just remove the tank and tip it up side down.
Old Nov 20, 2010 | 02:50 PM
Artlee's Avatar
Artlee
Suck on the vacuum line off of the petcock ( and it tastes like merde ) and then pinch it to maintain the vacuum. The gas will now flow.
Old Nov 20, 2010 | 03:56 PM
Nubz's Avatar
Nubz
put the cap on shake the **** out of it then toss in a match
that should take care of it
Old Nov 20, 2010 | 04:01 PM
Mike T's Avatar
Mike T
If the tank won't drain,good,pull that sucker off.
Old Nov 20, 2010 | 04:33 PM
trozenhorse
do you think my mighty vac will do the trick so i dont have to stick that tube in my mouth?
Old Nov 20, 2010 | 05:03 PM
Artlee's Avatar
Artlee
Mais oui
Old Nov 20, 2010 | 05:17 PM
dwyleecoyote's Avatar
dwyleecoyote
Yes. use your mighty vac. I have seen it done a few hundred times that way. Also, get a book.
Old Nov 20, 2010 | 05:22 PM
xFreebirdx's Avatar
xFreebirdx
It might......but its going to take a dam long time draining a full tank out the 1/4" line. It will be a lot quicker to remove the tank and pour the fuel out.
Old Nov 20, 2010 | 05:26 PM
Scratt's Avatar
Scratt
If it's a vacuum petcock you will see a separate hose besides the fuel line off the petcock.
