Vented Gas Cap???
Old Sep 30, 2014 | 07:55 AM
grbrown's Avatar
grbrown
I've owned my bike from new, an International model. It will take you a few moments to take a look at your own tank, to see if yours has one!
Old Sep 30, 2014 | 08:17 AM
92Fatty's Avatar
92Fatty
I know when mine my vent was clogged it was forcing fuel up out of the cap seal. Check your vent line and make sure it isn't restricted. Mine went under the seat and the aftermarket seat was pinching. it.
Old Sep 30, 2014 | 09:39 AM
Kabear's Avatar
Kabear
EPA restricts the release of "vapors" into the atmosphere.
Therefore your fuel cap prevents gas vapors going out of the tank, but allows air into the tank when engine is running, a simple reed valve type system, you can demolish the system and cause no harm to come to your bike or engine.
Pressure builds up when you shut down ie: to refuel and the heat off of the engine causes the fuel to expand and build pressure.
This is what the carbon filter canister is for on most vehicles. Maybe yours was set-up for California and then sent somewhere else so they removed the canister and plugged the line. Or you have a canister and that vent is plugged.
Just my $0.02
Old Oct 1, 2014 | 11:59 AM
tomfiii's Avatar
tomfiii
My friends was pissing gas out of carb when hot and I drilled out bung and put vent tube on it as gas caps are not available and his required a lot of pressure to bypass for some reason.
Cowboy812
EVO
38
Feb 16, 2020 10:29 PM
cwsharp
Jul 19, 2018 01:13 PM
JohnnyC
EVO
20
Sep 20, 2015 08:24 PM
cwhite6
EVO
May 2, 2012 01:13 PM
elevenbravo78
EVO
May 7, 2010 07:15 AM
